MP4 is a common format that is supported by nearly all video players. So if you want to watch your Blu-ray movie on a computer without a Blu-ray optical drive or on your portable devices, you can rip the Blu-ray to MP4 to play it. DVDFab Blu-ray ripper is a powerful Blu-ray to MP4 converter, with which you can convert Blu-ray to MP4 easily and customize the MP4 video to fulfill your specific needs. Now I will show you how to convert Blu-ray to MP4 with DVDFab Blu-ray Ripper.
How to Rip and Convert Blu-ray to MP4: Step 1 > Run DVDFab 10, choose the Ripper module and load the source.
How to Rip and Convert Blu-ray to MP4: Step 2 > Navigate to the profile library on the top left corner of the main interface and choose Format > Video > MP4. There are four profiles for MP4, and you can choose the one you need.
How to Rip and Convert Blu-ray to MP4: Step 3 > After the source is loaded in, the longest title, namely the main movie, will be selected by default. But here you can choose other titles. You also can choose the chapters, audio tracks, subtitles, define the names of the chosen titles, and do advanced settings according to your needs. You are even able to edit the Blu-ray video with the built-in editor.
How to Rip and Convert Blu-ray to MP4: Step 4 > Click the "folder" button to select a directory to save the output video. And then you can click the "Start" button to start the ripping process.
DVDFab Blu-ray Ripper also contains many profiles preprogrammed for specific devices. For example, there are several profiles for iPad in DVDFab Blu-ray Ripper. Therefore, it is also a great Blu-ray to iPad ripper.
